Shut off solenoid
Shut off solenoid
Postby 6LCummins » Wed Sep 12, 2007 1:33 pm
Hey all. long time no have internet:D. so i went and pulled last weekend will ill results. the wire on the solenoid was gettin torqued enough to kill the motor. so im wonderin if anyone knows the thread count of the stud on the shut off solenoid????
6LCummins
Postby PToombs » Wed Sep 12, 2007 5:06 pm
It's metric, did you lose the nut? Most people remove (discard) the spade end, and put a ring terminal on the wire. Less chance of it popping off.
Postby 6LCummins » Wed Sep 12, 2007 7:11 pm
wat nut??? mine doesnt have a nut on there. im lookin at puttin 2 nuts on it and puttin an eyelet on it to stop it from wigglin and killin the truck durin 2nd gear launchs on the sled. if anyone knows the threa or wat nut it is plz let me know b4 i go experimenting.
Nicholas
6LCummins
Postby Begle1 » Wed Sep 12, 2007 7:37 pm
6LCummins wrote: im lookin at puttin 2 nuts on it and puttin an eyelet on it to stop it from wigglin and killin the truck durin 2nd gear launchs on the sled.
Nicholas
Ouch.
Get any tailgate damage out of that one?
Postby 6LCummins » Wed Sep 12, 2007 9:04 pm
no damage it hit hte reciever not the truck. i just dont like lookin like an ass since im usually the only one that knows wat is goin on. most the time its local boys just coming to see how the farm truck runs.
6LCummins
Postby PToombs » Thu Sep 13, 2007 3:19 pm
I might have an extra, where ya at?
Postby 6LCummins » Fri Sep 14, 2007 11:59 am
I went to a bosch dealer down the street from where i work. they gave me a junk shut off solenoid. came to work today and checked the threads. for everyone needin or wanting to know the thread is: M5 x .80. Napa has the nuts for it so im rewiring it tonight to hopefully solve my problem. Thanks for offerin a spare one, since i have this one i think ill be ok. if it acts up again im lookin into a cable pull for it.
6LCummins
Postby Rampower » Thu Sep 20, 2007 6:58 am
Just put the cable on it and pull it. You probably will sooner or later anyhow. :lol:
92 ext cab 4x4. HT62-14, 4" straight pipe, BHAF, O-ringed, Haisley head studs, Ported head, exhaust, and turbo. Fuel pin, 4,000 gov spring,
Rampower
Postby Begle1 » Thu Sep 20, 2007 7:18 am
Rampower wrote:Just put the cable on it and pull it. You probably will sooner or later anyhow. :lol:
And then use your solenoid as an anti-theft device. 8)
