fuel additive
fuel additive
Postby remi » Fri Jan 20, 2012 6:12 pm
what kind of fuel additive or treatment are you running
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: fuel additive
Postby CumminsPower59 » Fri Jan 20, 2012 6:20 pm
I run Power Service when the temps start getting lower, and I am running B2 also, I know it won't gel as fast as B5 or B20, but I don't want to take a chance as my truck sits alot now that I have a VW TDI to commute in. Never had an issue with Power Service so far...
Re: fuel additive
Postby PToombs » Fri Jan 20, 2012 6:27 pm
Power service or Stanadyne. Had good luck with both, but I like the Stanadyne a little better, it doesn't small as bad if it dribbles under the seat. ;)
Re: fuel additive
Postby CumminsPower59 » Fri Jan 20, 2012 6:29 pm
Why would you keep it under the seat if you got that ginormous tool box on the back??? :lol:
Re: fuel additive
Postby remi » Fri Jan 20, 2012 6:30 pm
I've heard stynadyne is fairly good
remi
Re: fuel additive
Postby CumminsPower59 » Fri Jan 20, 2012 6:32 pm
I have been thinking of switching to that stuff, the local pump shop has tons of it (literally) and they have been having a sale on it, I can get it in 5 gallon cans on the cheap...if it's good enough for Pete, good enough for me ;)
Re: fuel additive
Postby Hansen01 » Fri Jan 20, 2012 6:33 pm
howes, no trouble yet, except when i go real watery fuel last year, the next day at the gas station all the pumps were frozen, even the gas pumps!! :shock:
Under construction...
Hansen01
Re: fuel additive
Postby PToombs » Fri Jan 20, 2012 6:35 pm
Uhhh, I haven't put it on yet. I've been hauling firewood and don't know when from day to day. Both trucks are drilled for it so it's an easy install. The worst part is listening to the kids whine because they have to run the air wrench. Something about how loud it is with their head inside the box? :lol:
Re: fuel additive
Postby cmann250 » Sat Jan 21, 2012 10:03 am
I use Power Service, silver bottle in the summer and white bottle in the winter. I get better mileage, at least mentally, using an additive :lol: Adding lubricity that our government kindly took out of our fuel helps too
Re: fuel additive
Postby thrashingcows » Sun Jan 22, 2012 2:22 pm
cmann250 wrote:I use Power Service, silver bottle in the summer and white bottle in the winter. I get better mileage, at least mentally, using an additive :lol: Adding lubricity that our government kindly took out of our fuel helps too
Yup exactly what I do to.... :D
thrashingcows
Re: fuel additive
Postby scottdevall@yahoo.com » Wed Feb 22, 2012 10:34 pm
i use power service on my truck and it seems to add a extra 2 mpg on my truck average cant explain why but ya. espically a lot of street light to street light of so cal
Re: fuel additive
Postby Diesel Dawg » Thu Feb 23, 2012 1:45 am
Dont use any except alittle 2-stroke oil now and then. :bom:
Diesel Dawg
Re: fuel additive
Postby Greenleaf » Thu Feb 23, 2012 10:55 am
Schaeffer All Season Soy Shield/Synshield. You won't want to get this on your hands nor have it spill inside the cab.
It is a super concentrated soy oil w/some antigel. It works. I have also used it on the CAT C7 ACERT engines and they are known to stick injectors. They don't with this stuff. They also start well in the cold with the additive. Otherwise they won't w/o the block heater. I mean they won't fire and run even at 35°F with out block heat.
Greenleaf
tech specialist/mod
