Specific VE leak please help video included
Postby raywinston512 » Tue Jan 24, 2012 10:40 am
Here is the link from cumminsforum which is completely worthless in most cases.
http://www.cumminsforum.com/forum/89-93 ... -help.html
raywinston512
Re: Specific VE leak please help video included
Postby ahale2772 » Tue Jan 24, 2012 11:51 am
looks like the return banjo
Postby cmann250 » Tue Jan 24, 2012 4:03 pm
Looks like ahale is correct. A couple folks on CF answered, but I'll answer here too. If my memory serves me correctly, there should be a copper washer on either side of that banjo bolt. DGK 121 is the P/N for a reseal kit, it's like $20. It will fix your next leak too ;)
Postby Hansen01 » Tue Jan 24, 2012 4:42 pm
is it the overflow? kinda hard to see in the video, but thats what i got out of it
Under construction...
Hansen01
Postby ahale2772 » Tue Jan 24, 2012 4:46 pm
over flow... return... whatever you want to call it
Postby raywinston512 » Wed Jan 25, 2012 1:22 pm
Ya it looks like overflow.
I am doing a buildup thread on the forum because i have to much time on my hands right now. There is a photo of the ve with the afc housing off. THANKS GUYS I REALLY NEED THIS LEAK FIXED. But i have the banjo washers BUT my banjo bolt is cracked which may be the whole problem, here is the link. NEED PAINT SUGGESTIONS
http://www.cumminsforum.com/forum/89-93 ... b-4x4.html
raywinston512
Postby raywinston512 » Wed Jan 25, 2012 1:33 pm
My truck is going to fuel real wierd.
raywinston512
Postby raywinston512 » Thu Jan 26, 2012 1:45 pm
Is this banjo bolt suppose to have two washers? May explain my leak...
By wittmaster512 at 2012-01-26
raywinston512
Postby ahale2772 » Thu Jan 26, 2012 4:23 pm
it is, sometimes one may fall without you knowing it
Postby wittmaster512 » Sun Jan 29, 2012 2:06 pm
Ya I got the washer now I am having trouble putting the throttle mechanism back together. Sure I can figure it out though.
Uploaded with ImageShack.us
wittmaster512
Postby 921stgen » Mon Jan 30, 2012 6:45 pm
http://dens-site.net/Dodge_CTD/Governor ... index.html
Maybe the pictures in the post will help.
921stgen
Postby wittmaster512 » Tue Jan 31, 2012 3:01 pm
921stgen wrote:http://dens-site.net/Dodge_CTD/Governor_Spring/index.html
Thanks man that solved it.
wittmaster512
