HELP!!! wont start
HELP!!! wont start
Postby jacobwebb57 » Thu Jan 26, 2012 8:04 pm
ok so truck ran fine. i put a raptor 150 on and it wont start..i bled all the air out i could via the banjo bolt onthe filter, it woult turn over but it wouldnt start. bled all injector lines and still wont start.. i have air i have fuel and the starter works what else is thier? need help bad..any and all imput is helpfull..thanks inadvance
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: HELP!!! wont start
Postby ellis93 » Thu Jan 26, 2012 9:14 pm
Is there a good spray coming out of the injector lines?
Postby jacobwebb57 » Fri Jan 27, 2012 4:23 am
ya i didnt pull the injector but i just loosened the line to the top but it shot out pretty good
jacobwebb57
Postby Hansen01 » Fri Jan 27, 2012 6:00 am
check the obviouse like the wire that goes to your pump?
Under construction...
Hansen01
Postby ellis93 » Fri Jan 27, 2012 6:04 am
^^^thats what I was getting to. The kill Solenoid wire could have a bad connection,coming/going thing.
Postby cmann250 » Fri Jan 27, 2012 7:02 am
ellis93 wrote:^^^thats what I was getting to. The kill Solenoid wire could have a bad connection,coming/going thing.
Those spade connectors wear out fairly easily and rattle themselves loose. They bit me once :lol:
Postby jacobwebb57 » Fri Jan 27, 2012 2:01 pm
the ip or the lp bc i can hear the lp running so i know it s not that and all the injectors are getting fuel mayby not enough? .. is their anywhat to blead the ip so i can make sure their is no air inthat? anyother ideas.. i will check all the wires just to make sure
jacobwebb57
Postby cmann250 » Fri Jan 27, 2012 5:54 pm
Check the wires on the injection pump, especially the one right above where the injector lines leave the pump (FSS). I don't think it's possible to bleed the IP. Once the injectors are bled, the IP is automatically bled.
Postby jacobwebb57 » Fri Jan 27, 2012 10:21 pm
it was that wire hookedc it up charged the battery and she started right up
jacobwebb57
Postby Hansen01 » Sat Jan 28, 2012 5:57 am
good deal :D , im always knockin that wire off mine
Hansen01
