Looking at the top of the gear,pump and gear on the truck,cover off. Which way does the gear turn to advace the timing?
Want to jump one tooth,that's puts the 1/8 advance in with the marks lined on the case and pump,right?
BC847 wrote:Looking at the gears from the front of the truck, moving the IP gear Clockwise advances the timing
cmann250 wrote:I think then you would jump a tooth CCW to get advanced timing.
