high rpm engine pulse
Postby tim curran » Sun Feb 19, 2012 3:42 pm
I installed an industrial injection leval 2 inj. Pump on my truck now when I give it full throttle it kind of pulses under load. It still gets good fuel milage for what it is 15 or so but I wonder if my timing is off a little. Any body got a thought. :?
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Re: high rpm engine pulse
Postby BC847 » Sun Feb 19, 2012 4:13 pm
"industrial injection leval 2 inj. Pump"
Hey Tim,
What is involved in that pump. I'm looking at your Sig and am confused.
What kind of lift-pump are you running?
Are you perhaps talking about the turbo surging?
Postby skilletky » Sun Feb 19, 2012 4:25 pm
Mine does the same thing. The more timing I give it, the more it is noticeable. I'm running a factory pump that's turned up and 7x.015 injectors. It drives me nuts
skilletky
Postby tim curran » Sun Feb 19, 2012 7:31 pm
My old pump died so I got a pump from ind. Inj. 3200 springs and there fuel pin I put my deny t p :o in back in it is just a rebuilt pump with the basic goodies not legal in california like most things I dont think it is aturbo surge because this pump isn't cranked up like my old one. I am using a stock lift pump with a 10 psi electric pump. It didn't have this problem before I changed the pump. It has good pulling power towing a trailer I get 38 psi of boost it just pulses under real heavy throttle
tim curran
Postby skilletky » Sun Feb 19, 2012 9:20 pm
Mine didn't do it either till I swapped ip. Probably gonna get a scheid pump to rePlace my current one.
skilletky
