inection pump leaking in to timing cover
Postby TEXAS_OUTLAW » Fri Feb 24, 2012 8:08 pm
hey all
well i got a 1993 and the inhection pump is leaking in to the timing cover ? :shock: :shock: :shock: i bought the triagle gasket to repalce it but is the pump bad and i heard of people changing it with out taking the pump out ? or maby i bought the wrong gasket !! can some one help me !!! thanks !!! :oops:
2008 2500 6 speed 4x4 : EFI LIVE ,South bend dual disc , 4 in to 6 in stack egr and dpf got stolen
1993 w250 5 speed 4x4 : under DEconstrution
1987 k30 4x4 crew cab dually : under construction
TEXAS_OUTLAW
Re: inection pump leaking in to timing cover
Postby ellis93 » Fri Feb 24, 2012 9:19 pm
Its the IP shaft seal,you can buy a seal kit off of ebay for 40$ and it'll have that seal.
Those that change the seal without taking off the pump,strip the front ofthe motor. I'd pull the pump
