Alternator wiring???
Postby Deathrod » Fri Feb 24, 2012 11:05 pm
I got my motor running but it's not charging.....I adapted the alt wiring to a universal hot rod wiring harness. Should the alt put out power just by spinning or does something have to tell it to? Any one have an idea how to get it to work with a harness made for a gasser?
Deathrod
Re: Alternator wiring???
Postby dazedandconfused » Sat Feb 25, 2012 6:30 am
Your going to have to wire in an external voltage regulator or swicth to a one wire alternator. It depends on if you want the extra wiring.
Postby Tacoclaw » Sat Feb 25, 2012 8:55 am
I had it all typed out, but it's easier to see in pics, so here's some pics. Sorry they're so big. :oops:
If you can't see them all right-click and select "view image".
Lifted from Here
Postby ellis93 » Sat Feb 25, 2012 11:49 am
Buy a one wire ac delco alt and forget it.
there seem to be someone having regulater issue all the time on here, I wouldn't to it to myself 8)
Postby Deathrod » Sat Feb 25, 2012 10:01 pm
Well there is a green wire and blue wire coming off the the plug, I ran them back to the regulator and heard the blue wire needed 12v from the ignition to tell the alt to charge. And obviously the power wire to the battery and ground to ground.....does this seem right?
Deathrod
Postby VanillaGorilla » Sat Feb 25, 2012 11:00 pm
I have an external voltage regulator in mine, was there when I got it. Now I have a charging problem and it burned the diode in the alternator. What I really don't get is why this voltage reg. seems to be causing a draw and my amp gauge moves around a lot, it's moved a lot the whole time I've had it so IDK what "normal" is
93 Reg cab LE 4x4 518AT, 145k and counting, pump turned up,Internal pump mods, Denny T stage 2, non IC DV's, timing bumped up, BD 40hp injectors,BHAF and me-built mandrel bent CAI,4" turbo back, Holley lift pump, new white with gold paint job, recieving more mods to tow the Duster and push this stupid WI snow.
VanillaGorilla
Postby Deathrod » Sun Feb 26, 2012 10:02 am
Just noticed on that diagram the voltage regulator needs to be grounded.....mines just sitting there.....I'll try that. Would that have fried it already?
Deathrod
Postby VanillaGorilla » Tue Feb 28, 2012 6:52 pm
Possible but a lot of them are grounded just by being bolted to a metal surface (clean)
VanillaGorilla
Postby Deathrod » Thu Mar 01, 2012 8:13 pm
got it working it did just need to be grounded....14.8v...seems a bit hit but i the airbag compressor will like it
Deathrod
