by Remps » Mon Mar 26, 2012 9:02 pm
What washers do you have on the injectors? .020 would be ideal, they are really thin. Try adjusting the smoke screw so that it is flush inside the afc top. (ccw) As long as the starwheel isn't bottomed out, it should be fine. Or does it smoke when accelerating now that you turned it up more? If it does you could set the starwheel where you like it best. Smoke screw and washers are going to affect the idle haze, as well as the full power screw. IC trucks also haze more with the smaller piston bowls IMO.
