Where to buy turbo oil fitting HX35?
Postby 1990BamaCummins » Sun Feb 26, 2012 1:40 pm
I just purchased an HX35 with 16cm housing and the oil pressure line adapter fitting isnt in it like the intercooled first gens. Mine is a 1990 and from what i read the intercooled trucks had the fitting you need.
Pure diesel power sells one but the picture doesnt look like what i need. Its an o-ring style adapter fitting that threads into the turbo (male end) and the oil pressure line threads into adapter fitting (female end) My oil pressure line IDK what size it is but is a male fitting that has a regular double flared end.
If anyone knows where to buy one of these adapter fittings and know the thread sizes for the adapter fitting that would be awesome.
From what i read the adapter fitting threads are 12mm x 1.50 that thread into the turbo. Idk what thread or size the oil pressure line are? Or what the adapter fitting thread size (female side) needs to be so i can thread the oil pressure line into adapter fitting that would already be threaded into the turbo.
If anyone knows i would greatly appreciate it.
Thanks in advance guys.
-Dale
Dodge Makes it Cummins Shakes it!!!
1990BamaCummins
Re: Where to buy turbo oil fitting HX35?
Postby bmoeller » Mon Feb 27, 2012 12:00 am
Cummins sells it. Don't have the p/n handy though. Less than $10, IIRC.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby 1990BamaCummins » Mon Feb 27, 2012 4:49 pm
I can just call cummins and tell em what im looking for and they'll know? Thanks BMOELLER!
1990BamaCummins
Postby Tacoclaw » Mon Feb 27, 2012 5:28 pm
I believe it's the same adapter on the oil filter side of the hose. You could pop it off and see if there's a Cummins number on it somewhere.
Postby 1990BamaCummins » Mon Feb 27, 2012 8:27 pm
Yea i saw that they were the same but no part number on it just a weird design. Thanks for posting on the thread tho TACOCLAW.
1990BamaCummins
Postby rattlebox93 » Sat Mar 03, 2012 7:27 am
Just get a couple 12-1.50 to -6 an fittings a 90* swivel a strait and a couple feet of -6 an hose and it will be all pretty!
rattlebox93
Postby 1990BamaCummins » Sun Mar 04, 2012 12:45 am
Sounds like more money and time lol i was hopin to just get the fitting and tighten it up and be done but didnt know it was such a PITA to get a D*MN fitting.
I wish it was already on the turbo when i got it but thats my luck. Thats how things go for me, 1 step forward, 3 steps backward.
1990BamaCummins
Postby bmoeller » Tue Mar 20, 2012 6:09 pm
My local Cummins shop is a PITA. They won't look ANYTHING up without a ESN. Even for something that is a common part on these engines. The new 6.7L uses the same adapter too.
bmoeller
Postby 1990BamaCummins » Mon Mar 26, 2012 12:25 pm
Cool, thank bmoeller. I havent gotten one yet but going to. looking into rebuilding my getrag 4x4. Never done it before but going to try and tackle it. I have the know how but like i said, never done it so thats coming first. Im going to start a thread to see if someone could guide me through it to see make sure im going to do it right the first time and not have to pull the trans back out.
1990BamaCummins
Postby ellis93 » Mon Mar 26, 2012 2:08 pm
Not tootin my own horn here :lol:
viewtopic.php?f=3&t=12097
Postby Tacoclaw » Mon Mar 26, 2012 4:35 pm
And not to toot mine:
Tacoclaw wrote:I happened across 2 of the HX35 fittings in my garage while I was cleaning up and putting stuff on my truck. If anyone needs them, I'd gladly loan them out until you found a replacement.
I say loan them out since I hate to get rid of something that I may end up needing myself sometime, but as of right now they're not doing anything.
Since you need it and I'll have one left, you can go ahead and have it.
Just PM me your Address and I'll get it shipped out.
Postby skilletky » Wed Mar 28, 2012 5:44 pm
3919687 is the current cummins part# for the fitting. PDP has them for 10.00 dollars, 21.00 shipped to your door.
skilletky
Postby 1990BamaCummins » Thu Mar 29, 2012 12:19 pm
PDP on the website that fitting doesnt look like the one i need by the picture.
1990BamaCummins
Postby skilletky » Thu Mar 29, 2012 1:28 pm
I called around to make sure it was the correct fitting and it is. The pic is for representation only I guess. I got one on the way. I'll let y'all know if it for sure the right one
skilletky
Postby skilletky » Fri Mar 30, 2012 4:47 pm
its the correct fitting
skilletky
