Cummins 855 Turbo
Cummins 855 Turbo
Postby nolafishr » Mon Feb 27, 2012 5:54 am
I am looking at a Turbo from a 855 Engine, it is a nice size Turbo and a good price. I am wondering if this would fit on
my 93 12 valve. I don't know much about it. Would it make a good upgrade or is it better used in compound turbos? Does anyone know about them and the specs on them?
nolafishr
Re: Cummins 855 Turbo
Postby skilletky » Mon Feb 27, 2012 9:18 am
That would be too big as a single. They used t50's and ht3b's on the 855. I could be wrong though
skilletky
Postby nolafishr » Mon Feb 27, 2012 10:38 am
Yeah that is what I was reading about them, it is a big turbo.
nolafishr
Postby skilletky » Mon Feb 27, 2012 10:49 am
It's pretty large. Around 71 or 74 mm depending on what model
skilletky
Postby oldestof11 » Mon Feb 27, 2012 3:48 pm
92SmokinBlacky on DTR ran an Aurora 5000 (71mm compressor, 2.8" bore)as a single on PODs. Ran really good. Said it was as laggy as the 21cm H1C he had on it before.
Postby skilletky » Mon Feb 27, 2012 3:58 pm
What size exhaust is on the 5000? One would have to put a pretty small, compared to what is on it, exhaust housing on a ht3b to run it as a single and get somewhat decent spool up I would think. But I've never done it so I could be wrong.
skilletky
Postby oldestof11 » Mon Feb 27, 2012 4:38 pm
It is bigger. This turbo is used as the low pressure/atmosphere turbo in there 3000/5000 twin setup.
Here you go:
http://www.youtube.com/user/BlackSmokin ... qwL4O9JeCU
Postby PToombs » Mon Feb 27, 2012 5:48 pm
It might also be an HT4B, way too huge for a 5.9 to spool!
Postby rattlebox93 » Sat Mar 03, 2012 7:33 am
My friend has a turbo off a 290 cummins and idk exactly what it is but it is effin huge it has to be 80+ mm an besides you will never get that big ass downpipe through without bashing your floor in..... And the 28cm t6 housing will never spool!
rattlebox93
Postby ditchman24 » Wed Mar 07, 2012 6:35 am
If you get it cheap enough,try it. If it dosen't work resell it, you might even make a buck ot two.
"If it don't fit force it, if it brakes it needed replaced anyways"
ditchman24
