Mystery pump bolt
Mystery pump bolt
Postby m880cummins » Mon Mar 05, 2012 8:20 pm
Hi,
Can someone tell me what this bolt is next to the mounting nut? (scroll down page) Mine is loose and does not have that tab.
Charlie
SUNY Maritime Class of 2017!
m880cummins
Re: Mystery pump bolt
Postby BC847 » Mon Mar 05, 2012 8:57 pm
Charlie,
Did you mean to include a link to an article? Scroll down what? :?:
Postby m880cummins » Tue Mar 06, 2012 5:22 pm
m880cummins
Postby AHineman » Tue Mar 06, 2012 5:59 pm
That's the bolt you tighten up if you want to lock the pump for removal.
Postby Tacoclaw » Tue Mar 06, 2012 6:41 pm
Yup, you loosen it and pull that plate out. That lets you thread the nut in even farther than usual, though if you don't have the pump at #1 I'm not sure it'll even thread in...
Postby m880cummins » Tue Mar 06, 2012 6:49 pm
SH**!!!!
The plate is missing from mine and it is in the locked position. My engine rattles pretty bad under load...Would metal go through my injectors if it was rubbing?
Charlie
m880cummins
Postby PToombs » Wed Mar 07, 2012 6:12 pm
Oh yeah! :( There is a point on it that jabs into the rotating piece in the pump, like a set screw. If when the pump was installed the screw wasn't backed out, there's probably a lot of metal floating around in there. Not good!
Postby m880cummins » Wed Mar 07, 2012 8:10 pm
Well at least i didn't see anything when I did the 366 spring. Who knows about the rotor though...
Charlie
m880cummins
Postby Mark Nixon » Sat Mar 10, 2012 8:08 am
The one in the picture HAS the plate still in place.
It's the little piece of tin under the head of that bolt.
Unless that's not a pic of YOUR engine, you should be fine.
Postby m880cummins » Sat Mar 10, 2012 4:35 pm
Not my engine in the picture.
Charlie
m880cummins
Postby Mark Nixon » Sat Mar 10, 2012 6:18 pm
Okay.
Simple check, pull the bolt and see if it's even the correct one and see if the tip is missing.
Postby m880cummins » Wed Mar 14, 2012 11:44 am
Took the bolt out and it had a divot wore into it from rubbing on the rotor shaft. I used a washer to shim it up and it still runs fine so I guess I lucked out.
Now to deal with my dropping fuel pressure that started yesterday.....
Charlie
m880cummins
