How hot is HOT?
How hot is HOT?
Postby rattlebox93 » Thu Mar 08, 2012 10:06 am
Last night i got rid of my worn factory ball and socket throttle linkage and made a deal out of sweged tube and heim joints. whil messing with it i also reinstalled my 4200 spring and did about a 3/16" timing bump (also has a tooth jumped and pump was all the way retarded).... i tool it out and make a pass down a country road it it got to about 1250 or soo i kow a commonrail it as nothing to see 1800*'s but is 12-1300 hot for a 12v i have coated pistons so that should help.. will more timing help cool it? what do you guys think? also the engine is painted with the good actual cummins brand paint and in the 5xxx or som miles since beeing put back togeather it never even so much as blackened an exhaust runner and after last night all 6 are black..... ok well opinions would be greatly appreciated thanks dj
rattlebox93
Re: How hot is HOT?
Postby BILTIT » Thu Mar 08, 2012 3:15 pm
Cummins rated these engines at 1250 100% duty cycle (continous). They can handle higher for short periods.
Derek B.
BILTIT
Re: How hot is HOT?
Postby oldestof11 » Thu Mar 08, 2012 3:24 pm
And you have coated pistons. Good for 1400 or more.
Re: How hot is HOT?
Postby Hansen01 » Thu Mar 08, 2012 6:22 pm
i run 1400 degrees all the time if i get on it, no longer than 10 seconds tho, ive also had it up to 1600+ a couple of times. Ive had the head off twice and pistons looked like new both times. i think it reaks more havic on yur head than pistons, as my head was toast :roll:
Under construction...
Hansen01
Re: How hot is HOT?
Postby remi » Thu Mar 08, 2012 7:36 pm
are these temps pre or post turbo
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: How hot is HOT?
Postby The_Head » Thu Mar 08, 2012 7:42 pm
pre turbo
The_Head
Re: How hot is HOT?
Postby rattlebox93 » Fri Mar 09, 2012 11:25 am
Pre turbo
rattlebox93
Re: How hot is HOT?
Postby RumbleFish » Fri Mar 09, 2012 1:31 pm
Pre turbo
Re: How hot is HOT?
Postby Tacoclaw » Fri Mar 09, 2012 2:21 pm
Pre turbo.
Re: How hot is HOT?
Postby Tsbourne09 » Fri Mar 09, 2012 4:43 pm
Pre turbo.
Not On Yet: 60#VS
Tsbourne09
Re: How hot is HOT?
Postby oldestof11 » Fri Mar 09, 2012 5:30 pm
Puuuuurrrrrr...... Post turbo 1400 you should be fine with coated pistons. :lol:
