Help identify motor
Help identify motor
Postby rx7_guy » Sun Mar 18, 2012 5:42 pm
Hey there guys, I just got this motor in trade and Im wondering if you can help identify it. Its from an industrial application was told possibly a grader, it has an odd looking turbo manifold. Anyways here are the numbers
Engine Serial No. 44266289
Injector Pt. No. 3909476
Cust. Spec. 41554
CLP 0597
Built 06/03/88
rx7_guy
Re: Help identify motor
Postby BC847 » Sun Mar 18, 2012 6:29 pm
Got any pictures?
Postby rx7_guy » Sun Mar 18, 2012 6:44 pm
Ill grab some pics tomorrow. Its all shrink wrapped up, got it in trade for about 2 hrs of tig welding so even if its junk i didnt come out to bad.
rx7_guy
Postby oldestof11 » Sun Mar 18, 2012 7:00 pm
Is it a Cummins?
It could have a Bosch A pump on it. The thing I would want most is the pistons. The non-IC'd and industrial engines got a piston with a wider injector bowl allowing for more timing with regular IC'd injectors.
Postby rx7_guy » Sun Mar 18, 2012 7:15 pm
Before I left the shop i had wrote down the numbers posted above, here are a couple others that might help.
Rated hp - 152hp - 2500 rpm
fuel rate at rated hp 66.7 mm^3/stroke
TDC Plunger 1.5mm
It came with a transmission input adapter that is huge, will take pics of it all tomorrow
rx7_guy
Postby Dieselwrencher » Mon Mar 19, 2012 1:22 pm
I got this off of QuickServe. It looks to be a non intercooled industrial engine. Nothing wrong with that! Does it have the V-belt pulley bolted on with the harmonic balancer?
CPL#0938 "VE" type
(Non Certified) fuel pump for
152 BHP turbocharged "B"
series 6 cylinder engine at
2500 RPM with a peak torque
of 400 lbs. ft. at 1600 RPM.
Has 12 volt atr fuel soleniod
and 2.0mm tubing. With FR9036
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
