Egt probe location
Egt probe location
Postby cummins32 » Tue Mar 27, 2012 2:25 pm
Where should I put my egt probe at post turbo or pre tubro ? Thanks
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Egt probe location
Postby skilletky » Tue Mar 27, 2012 2:29 pm
Pre-turbo for more accurate readings
skilletky
Postby cmann250 » Tue Mar 27, 2012 2:31 pm
^ What he said, unless your downpipe already has a bung in it for that reason
Postby cummins32 » Tue Mar 27, 2012 4:37 pm
Ok Thanks guys, and I also read somewhere I want it close to the cylinder for an accurate reading ?
cummins32
Postby PToombs » Tue Mar 27, 2012 4:38 pm
Right in the manifold just before the turbo. Not dead in the middle though, there is a web there. Slightly to the front or back.
Users browsing this forum: No registered users and 66 guests
