Boost Question
Boost Question
Postby nolafishr » Wed Mar 28, 2012 4:34 am
How much boost can the first gen 12 valve engines handle before any mods have to be made to the engine/head?
nolafishr
Re: Boost Question
Postby Tacoclaw » Wed Mar 28, 2012 4:52 am
Before any mods? Probably around 25-30 depending on your timing. After a simple retorque to 125 ft/lbs you should be good to 40-50 depending on your timing.
Wastegating and exhaust back pressure tie into this somewhat as well, but not until around 50 or so with a tight housing.
Re: Boost Question
Postby cougar » Sat Mar 31, 2012 10:04 am
Most say anything over 40. I would also throw EGTs into that. The higher your peak EGT, the more I'd lower that number. But that's just me.
01 2500 "the work truck".
cougar
Re: Boost Question
Postby oldestof11 » Sat Mar 31, 2012 11:12 am
Boost:drive pressure ratio is the key. Also, head bolts torqued to 125lbs or new ones to 130 can hold quite a bit.
