by Tacoclaw » Wed Mar 28, 2012 8:49 am
The exhaust side should just be 4 or 6 bolts holding some circular clamps down. Break them loose, take out as many as you can, and start hammering the housing off. I say as many as you can, because one or two might unscrew up into the oil feed and drain area. Do not try to unscrew them past that, they will strip their holes out.
You can use them as pusher bolts, but again they strip easily so I would only reccomend using them to keep light pressure on it as you hammer. As you hammer it off don't let one side get ahead of the other. You will bind the turbine bades up in the housing and bend them. If you have to heat the housing; I always have, it makes it easier, use a really hot torch and get the housing hot ASAP. Don't keep heat on it any longer than you have to, it'll bleed Ito the center section and melt the seals. Those seals are tough, but they're not torch-tough.
When putting it back on, nev-R-sieze anything that touches anything. Once again, make sure your housing goes on straight so it doesn't hurt the blades, and remember to start those screws before you put it together since they won't be able to thread in once it's back together.
Oh, and there's no gasket on the exhaust side of the turbo. Its interference-fit, with a rust-gasket, which you'll ruin when you take it apart, but it'll seal back up when you put it together.
