injection pump leaking
Postby cummins32 » Thu Mar 29, 2012 7:05 pm
My injection pump was leaking tonight on the side closest to the fender any idea what it is ? Also when my friend shut it off I heard what sounded like air being sucked in by the exhaust, this is my first diesel and everythings scaring me haha
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: injection pump leaking
Postby CumminsPower59 » Thu Mar 29, 2012 7:11 pm
There are quite a few places on that side that could be leaking, KSB, shutdown lever o-ring, etc. Try and get 'er dryed off and run it for a minute and see if you can spot where it's coming from. Re-seal kits for the VE are plenty cheap ;)
Postby cummins32 » Thu Mar 29, 2012 7:40 pm
Ok thanks and any idea about the exhaust noise i was hearing
cummins32
Postby cummins32 » Thu Mar 29, 2012 7:57 pm
It's leaking from underneath the spring that's underneath the tps
cummins32
Postby CumminsPower59 » Fri Mar 30, 2012 5:00 am
Sounds like the o ring on the trottle shaft. The noise you heard from the exhaust is normal. When the engine is stopped, it takes a second or three for the turbo to stop spinning, it will make a little noise when doing so, like the sound of air moving.
Postby Black93 » Fri Mar 30, 2012 5:56 am
x2 on the throttle shaft seal. Might as well throw a gov spring in while you're in there. You can get a seal kit & spring for less than $50.
Black93
Users browsing this forum: No registered users and 63 guests
