Crusing stats
Crusing stats
Postby Tsbourne09 » Fri Mar 30, 2012 7:05 am
Goin down the hwy bored. Crusing stats!
70mph
14 psi fuel pressure
550 egt
10 psi boost
2500 rpm
150* tranny temp
62-65 oil pressure
12.5 volts
Full tank
207860 miles and still kickin!
Not On Yet: 60#VS
Tsbourne09
Re: Crusing stats
Postby Philip » Fri Mar 30, 2012 6:52 pm
EGT 800
fuel pressure 7 PSI
6 PSI boost
1750 RPM
full tank
220K miles.
Still rusting away :lol: :lol:
Re: Crusing stats
Postby Tacoclaw » Fri Mar 30, 2012 9:57 pm
60 mph
2psi
400 EGT
no more gauges... :oops:
Re: Crusing stats
Postby Deathrod » Fri Mar 30, 2012 10:46 pm
Don't have a clue......no gauges :shock:
Deathrod
Re: Crusing stats
Postby Tacoclaw » Fri Mar 30, 2012 10:50 pm
Deathrod wrote:Don't have a clue......no gauges
A man among boys. 8)
Re: Crusing stats
Postby 01hillbillycummins » Sat Mar 31, 2012 2:37 am
Deathrod wrote:Don't have a clue......no gauges :shock:
same here :shock: who knows
1990 w250 Denny T II pin, 3200 spring, BHAF, DE 4" TBE, 5" lift, 37" toyos, kelderman air ride, 75 gal aux fuel tank
01hillbillycummins
Re: Crusing stats
Postby cmann250 » Sat Mar 31, 2012 4:58 am
I call it living on the edge and trusting Cummins' proven platform :lol:
Re: Crusing stats
Postby cougar » Sat Mar 31, 2012 8:30 am
My 91
55mph
0 boost
600° egt
1425rpm
20 mpg
280K and no signs of slowing down
01 2500 "the work truck".
cougar
Re: Crusing stats
Postby jacobwebb57 » Sat Mar 31, 2012 8:59 am
70 mph
12 psi fuel pressure
550 egt
1800 rpm
15 psi boost
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: Crusing stats
Postby Deathrod » Sun Apr 01, 2012 10:07 pm
It drives me crazy with out them......but they are in the mail.. I can't really tune the IP to the he351ve without knowing my boost and egts... I'm already livin on the edge ridin in this death trap :D
Deathrod
Re: Crusing stats
Postby dunes450r » Mon Apr 02, 2012 8:19 am
60mph
600* egt
6 psi
60psi oil pressure
looks like i've got a trend for sixes :D
dunes450r
Re: Crusing stats
Postby 92strokersmoker » Sat Apr 07, 2012 6:46 pm
70mph
700 egt
6psi boost
1950 rpm
1/4 tank full....as usual
92 w250 NV4500, Denny T stage II, HE351, 5x.012, FPS maxed, 3200 spring, 1/4" timing bump, ALL guages, Carter fuel pump. And some more
92strokersmoker
Users browsing this forum: No registered users and 65 guests
