Anyone have any sugestions This is Parts list So far
Postby roxxx » Sun Sep 23, 2007 9:20 pm
BHAF With cummins Paper Filter With the Outerwear prefilter
(HTB2 62ss 16cm) ??? Don’t know if I need this high end of a turbo
New Era 370 or 435 or POD'S don’t want hazing though
Pulse Exhaust Manifold
4 inch pipe with a bit of a resonator Sadly I would like straight pipe but I think it would be a bit much
Old Smokey fuel pin
3200 GOV Spring
Maybe the 60 pound springs
Kdp KIT
would like to convert the headlights to HID Not to worried about yet
Flex-A-lite Diesel truck fan Later
So am i missing anything? I am looking for aroumd 300 plus HP at the rear wheel . i do need to keep this truck civil had a bit of probelm in the past with smoke :lol:
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby DTanklage » Mon Sep 24, 2007 10:59 am
think most guys are ordering that turbo with a 12 or a 14 housing
i just got mine with a 13 stainless housing and would love to compare it to the 14 cast
order yours with a 14 cast and we can switch for a minute to see which one ea of us likes better
i dont know how much fuel you are going to put to it but if want it to rip i dont think you will be happy with anything smaller than a s300 series turbo
in 62/65 config it makes the truck a totally different monster - again, never tried it in the stock 57/65 config so dont know the difference
when dont you want it to haze? at idle? cruising? towing? i dont know that you can put very much fuel to these old trucks w/o some haze somewheres.
don
DTanklage
well i have being emailin the guys at HHT
Postby roxxx » Mon Sep 24, 2007 4:10 pm
HTB2/62 Street Stock with a 14cm housing. This is were I am at right now. Would like to go a bit higher to the 64 but my luck i will have suge. heh read your post DTanklage i probably wont be able to aford ss anyways It s going to cost me a fortune to buy this in Canada
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby dpuckett » Mon Sep 24, 2007 6:36 pm
If you have haze, you have fuelling issues (or PODs). I've never been on a dyno except for emission testing in CO, so I cant compare numbers, but I have kept up with newer trucks (02 PSD auto, chip and exhaust) with little to no smoke at WOT. My current setup will let me make 38psi boost and a little poof of smoke til 15-1600RPM. Then nothing but noise and hauling butt.
Pump tuning and some 50-75hp injectors will top 300hp easily. Remember, timing can either help or hurt you- get is set right. It will be worth the $50 for the dial indicator if it will save a head gasket or fuel. Depending on injector pressures, I'd recommend 1.5-1.6mm. Any more than that, and I have found no improvement in performance, though my performance is judged by MPGs and towing torque, not necessarily absolute numbers.
Daniel
Re hazing i plan on getting the New era injectors
Postby roxxx » Tue Sep 25, 2007 7:45 am
common sense saz i should get the 370"s lol but I am leaning towards the 435 ‘s
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby Ichiro » Tue Sep 25, 2007 8:56 am
roxxx, did you get your 62/14 in Canada? If so, where...?? My wish list is similar to yours. Please keep up the post. BTW, I got the Stan's 4" turbo back...and it sounds awesome!!
'93 4x4, Ext Cab, 5-spd Getrag, Borgeson steering shaft, Stan's 4" SOLD
'98 4x4 QC NV4500 LWB
Ichiro
dang it now i have couple more choices in turbos
Postby roxxx » Tue Sep 25, 2007 11:24 am
Price wise i can go to the next town and he carries BD power in stock ( Super B Single Turbo)and goooood prices too And then there is peirs in BC 64/14 Custom built Schwitzer S300 these are a bit pricey
Ichiro What province do u live in ?
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby Ichiro » Tue Sep 25, 2007 2:41 pm
I'm in Kamloops, BC. I checked PDR and I really don't want to drop $1700 plus taxes (not as fortunate as you Albertans!). I'll look at hybird options.\I was just wondering because I have a friend in Cgy whom I can ask to some places out for me.
Ichiro
Nice to see a canuck on here
Postby roxxx » Tue Sep 25, 2007 3:25 pm
i just got a quote from the guy in the next town up from me (i dont live right in calagry) He is selling BD power and he quoted me 1300$ for the BD Super B single , I think i can work him on getting the Super B special for close to the same, PLus he has it in stock . I am going to see if i can talk my brother inlaw into buying at the same time. He just picked up 1St gen with the p pump. This guy has the dyno and all so i might even get to dyno the truck too
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby Ichiro » Tue Sep 25, 2007 7:37 pm
That's awesome! What kind of exhaust housing are you going to get? Sounds like they are way more reasonable out there! Gonna have to stop next month when I am thru... Keep up the post. Would like to know what the results are.
Mike
PS - are you getting injectors at the same time...??!!
Ichiro
Sure will. So far some good savings if i buy there
Postby roxxx » Tue Sep 25, 2007 10:54 pm
Sure will, they seem like pretty go shop. I am getting a quote from one other place .Going to save about 1000 bucks so far if i buy through his shop woooot,
I Dont think i will be able to get much better,I will try the group buy and see maybe i might get a better deal, who knows i have to try though I will keep ya pposted
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
