injection pump mounts- bolts or studs?
Postby fatstack » Sun Apr 08, 2012 10:48 am
Are the injection pump mounts bolts or studs? Where could one be sourced? Thanks
89 d250 getrag ripper, pump maxed,timed to the head,pull cable shutoff, 354 spring, straight pipe, 4:10 gears, in the shop: he351cw and 3:07 gears
90 w350 nv4500,ic motor, stock, 5" stack w a western hauler on back
fatstack
Re: injection pump mounts- bolts or studs?
Postby skilletky » Sun Apr 08, 2012 11:15 am
Studs. Can't remember what thread. I used bolts on mine when I broke the studs. If you use something other than factory studs, make sure they don't stick out inside the gear case too far.
skilletky
Postby fatstack » Sun Apr 08, 2012 6:01 pm
10 4. Thanks
fatstack
Postby fatstack » Wed Apr 11, 2012 7:20 pm
Dumb question: Are these studs the same length and thread on both ends? I apologize for the redundancy.
fatstack
Postby skilletky » Thu Apr 12, 2012 6:22 am
That I'm not sure on. I think the threads are the same on both ends and the end that screws into the gear case is shorter. But I could be wrong
skilletky
Postby ellis93 » Thu Apr 12, 2012 6:44 am
skilletky wrote:That I'm not sure on. I think the threads are the same on both ends and the end that screws into the gear case is shorter. But I could be wrong
Your not ;) that's how they are on mine
Postby fatstack » Fri Apr 13, 2012 3:56 pm
Thanks again for the support. I found some that should work out, 8m x 1.25.
fatstack
Users browsing this forum: No registered users and 65 guests
