1993 12 valve boost?
Postby TRACTJDS0428 » Fri Apr 13, 2012 9:15 am
what is the normal boost on a 12 valve with a non waste gated turbo? mine is completely stock and 25 to 28 psi is as high as mine gets. what is a good first upgrade and what kind of money am i gonna spend?
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
Re: 1993 12 valve boost?
Postby Tacoclaw » Fri Apr 13, 2012 9:22 am
viewtopic.php?f=4&t=12300
If you've already done everything in that thread, then a big air filter and 4" exhaust are the next mods usually.
If you've got that, then I guess te next question is what do you use your truck for?
Postby TRACTJDS0428 » Tue Apr 17, 2012 8:58 am
thanks for the link. lots of great info. still didnt see the stock boost numbers?
Also having a really hard time finding the low pressure lift pump. i went to oregon diesel and couldnt find it. does anyone have a part or kit#?
TRACTJDS0428
Postby cmann250 » Tue Apr 17, 2012 9:49 am
Here's what I got by crossing numbers. You'll have about another $80 wrapped up in the spacer plate, line, gaskets, etc. if you go this way.
It's HFP702, towards the bottom of the page http://oregonfuelinjection.com/index.php?pid=32
Postby BILTIT » Tue Apr 17, 2012 1:16 pm
I think your doing just fine if your getting 25psi of boost. I was getting 12psi with my stock 21cm H1C and i am now getting 28psi with my he351cw with 9cm2 housing. All with stock pump settings.
Derek B.
BILTIT
Postby Tacoclaw » Tue Apr 17, 2012 2:28 pm
Oh yeah I didn't really mention boost numbers, huh? :oops:
I'd say you're doing alright for an IC'd truck. My non-IC'd '90 would just edge out a 35psi gauge with it's stock 18cm turbo and injectors, but it wasn't doing itself any favors up there. :lol:
Postby TRACTJDS0428 » Wed Apr 18, 2012 8:58 am
OK. I found the pump. There is a thread on here that shows part numbers for a lift pump install. Are those the numbers i will need for the line and spacer plate....... or does oregon have a kit for the switch?
TRACTJDS0428
Postby cmann250 » Wed Apr 18, 2012 9:01 am
I got mine from Cummins. Those numbers are old, but they will cross to get the same thing
Postby TRACTJDS0428 » Wed Apr 18, 2012 9:03 am
BILTIT wrote:I think your doing just fine if your getting 25psi of boost. I was getting 12psi with my stock 21cm H1C and i am now getting 28psi with my he351cw with 9cm2 housing. All with stock pump settings.
my truck has always made 20 or higher so could i have the 9cm housing? how would i know. i know it had some power work before i bought it but dont know what all was done.
TRACTJDS0428
Postby TRACTJDS0428 » Wed Apr 18, 2012 9:04 am
cmann250 wrote:I got mine from Cummins. Those numbers are old, but they will cross to get the same thing
Thank you! you have been a great help.
TRACTJDS0428
Postby cmann250 » Wed Apr 18, 2012 9:23 am
You're welcome :wrench: If you have a stock turbo, you have an 18cm housing or maybe a 21cm housing. I'd bet it's 18
Postby TRACTJDS0428 » Thu Apr 19, 2012 8:46 am
I called my local dealer and they can get me all the swap parts except the spacer plate. the part number on here doesnt work they say. Could anyone get me a measurment on the exact thickness of the spacer so i could machine my own? Or a known good part number for the low pressure piston pump spacer needed for the swap from a diaphram style?
TRACTJDS0428
Postby cmann250 » Thu Apr 19, 2012 9:50 am
I took all those numbers to Scheid and they had no problems. Double check them, I often write things down wrong lol
Postby BILTIT » Thu Apr 19, 2012 10:34 am
As said above you probably have the 18. Pump may be turned up alittle aswell?
Derek B.
BILTIT
Users browsing this forum: No registered users and 57 guests
