by Black93 » Wed Apr 18, 2012 4:48 pm
The fuel heater does have an oring on top. I don't have the part # for it, but you can get it from Dodge. I think the last one I bought was about $3. The next time I change my fuel filter, I'm going to delete the heater. The heater delete stud is part # 3925954 $20 from Cummins & J925954 $10 from Case.
