belt tensioner
belt tensioner
Postby studie91 » Tue Apr 17, 2012 6:31 pm
i just redid my belt, belt tensioner, water pump, and valve cover gaskets on my 91 d-350 non intercooled. when i fired it up and did my final check over i noticed that my belt tensioner was slightly moving around. i went and looked at my 93 cummins and the tensioner doesnt move. i doesnt move much just a little bit.
1992 w250 ctd bone stock
1991 d350 ctd bone stock
1991 ramcharger 360
1981 plymoth trailduster 318
1959 studebaker truck
studie91
Re: belt tensioner
Postby bmoeller » Tue Apr 17, 2012 7:48 pm
New tensioner?
Is the little pin sitting in the proper hole, and the bolt is tight?
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: belt tensioner
Postby studie91 » Tue Apr 17, 2012 8:38 pm
yes it is new. i belive it is in the correct hole. i double checked the bolt and it is tight. maybe i will pull it off tmo after work and make sure its in the right spot.
1991 ramcharger 360
studie91
Re: belt tensioner
Postby bmoeller » Wed Apr 18, 2012 4:12 pm
If it's in the right hole, there is a possibility that they gave you the wrong one. They aren't all the same.
bmoeller
Re: belt tensioner
Postby PToombs » Wed Apr 18, 2012 5:28 pm
What do you mean "moving around"? The whole assembly shaking, the arm moving with the belt, arm moving towards the radiator and back, or what? The plate the tensioner bolts to could be loose, but I've never seen one yet.
Re: belt tensioner
Postby studie91 » Wed Apr 18, 2012 6:14 pm
1991 ramcharger 360
studie91
Re: belt tensioner
Postby cmann250 » Thu Apr 19, 2012 4:44 am
Mine twitches a little bit too. It could be that there's an accessory with a bad bearing on the front end, causing the belt to drag momentarily. Could be the idler. Pull the belt off and give everything a spin to feel for resistance
Re: belt tensioner
Postby PToombs » Thu Apr 19, 2012 5:29 pm
I see that on equipment all the time, it's what it's supposed to do. There may be some crap stuck in a pulley which pushes the belt out a little and then it drops back in or it may just be an imperfection in the belt.
