I did a cummins swap last year and the truck has never been a power house dead stock but ran ok.
Its an 89, VE pump of course, stock non I/C injectors, HE351 cw with the wastgate operational, 3.5" DP, full 3.5" exhaust with no muffler or cat, K&N filter right off the turbo.
I just put the he351 on 2 weeks ago, before that the baby h1c with 18cm housing would hit 20psi max.
Pump was dead stock rebuild, nothing done to it with the old turbo on it.
I changed to the he351 CW and the truck was a DOG, would not even break 50 MPH in 5th, period.
Would not break 15PSI max and simply had no power, no smoke at all where previouslty it was a little smokey down low but cleared up on top.
So, I had to turn the pump up to get it to run, so I went two turns in on the power screw and flipped the AFC pin around backwards.
It WOKE up, wouldl hit 32 PSI no problem, very responsive and way faster boost than the old baby h1c.
But, it did SMOKE like a freight train...so, I pulled back on the power screw one turn and the smoke dropped a little but still more than I like, especially down low and it wont really clean up on top either, at least not until the stock governer start pulling fuel and of course boost drops.
Right now I get 25 PSI with the pump one turn in over stock and the stock AFC pin backwards, nothing else done to the pump.
I had the injectors checked about a year ago before I swapped the engine in and they were in spec per the shop, what that means I dont know but it was a year ago.
I suspect an injector is clogged or to far out of spec and is hurting power and adding smoke.
It will blue smoke under a load, as in pulling a 7k trailer, I dont notice it unloaded pushin blue but it hazes at idle at times as well.
I have the ZF5 trans running an adapter plate, 4.10 gears, the truck is a 95 4 door long bed, 4wd F350
Also fuel mileage has been sucking the past 3 months and seemingly worse with the HE351 and my recent pump mods.
I get maybe 12mpg unloaded and 10 or so with a 7k load.
I have a carter black fuel pump, last time I checked it had 10PSI and plenty of volume.
Thanks,
Scott
