Cleaning Injector Bores
Postby Mike T. » Sat Sep 29, 2007 7:37 am
After you clean the bores with a brush do you turn the engine over to blow out the junk, or is there a better way?
Thanks
93 w350 ext. cab,auto,354s,4"exh., smokey mt.,bhaf,htb2 62/65/12,CoolerTubz, ddp 55lpm inj.,Timed 1/8,Valet Switch,Piston LP,mild pump,3200 spring,ddp pin,Goerend TC,25k gvw trans cooler, deep pan,gauges,egt is pre.
Mike T.
Postby meby » Sat Sep 29, 2007 9:05 am
compressed air, take an air nozzle with a really long tip and stick it all the way at the bottom and voila
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby Mike T. » Sat Sep 29, 2007 9:37 am
Thanks meby
Mike T.
Postby wannadiesel » Sat Sep 29, 2007 1:53 pm
Snap-On and others sell a brush for cleaning the injector bores.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Mike T. » Sun Sep 30, 2007 8:16 am
Thanks Dave, I bought one from Cummins.
Mike T.
