91.5 starting trouble
Postby Ryan » Sat Sep 29, 2007 1:27 pm
hello, I have a 91 1/2 truck 190000 (as if it matters) The truck will crank fine and once its running it runs perfectly and tows with no trouble. It used to crank and instantly fire, however now you have to crank it and crank it and crank it about 10-15 sec and hit the gas pedal to get it to fire, once its running you have to hold the pedal open about 2-3 sec or it will stall again. This has been goin on for about 2-3 weeks, my buddy helped me turn the fuel up about 2 months ago, so I don't think this is the cause. But just thought Id throw that in. I know alot about engines and all things gas, but im new to the diesel world so any help would be great. I read somewhere about a hole in the "suction" line and the pumps were essentally losing prime, don't know and Im not sure where that even is, im assuming in the tank.
Thanks,
Ryan
Ryan
Postby wannadiesel » Sat Sep 29, 2007 1:55 pm
Most likely you have a leak in the fuel line from the tank to the lift pump. The easiest way to find a leak id to remove the fuel cap, stuff a air hose and a rag down there, and put a few psi in the tank while somebody goes under the truck to look for drips.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Ryan » Sat Sep 29, 2007 3:25 pm
ok thanks...where is the lift pump located? I thought it was in the tank. guess not?
Ryan
Postby PToombs » Sat Sep 29, 2007 4:51 pm
It's on the drivers side of the engine, below the fuel filter. It looks like a chevy pump, except for the manual handle.
Postby RumbleFish » Sat Sep 29, 2007 5:02 pm
PToombs wrote:It looks like a chevy pump
are you allowed to say that on this board?
Postby PToombs » Sat Sep 29, 2007 5:05 pm
If the chevy has a Cummins in it, yeah! :wink:
