best way to free up the....
Postby swank » Sun Sep 30, 2007 11:53 am
little deal that rides on the fuel pin? a buddy is having some trouble getting it to move.
truck
swank
Postby Begle1 » Sun Sep 30, 2007 5:42 pm
Start the truck and do a couple donuts?
Postby swank » Sun Sep 30, 2007 6:06 pm
already attempted....
any other thoughts?
truck
swank
Postby Begle1 » Sun Sep 30, 2007 6:54 pm
Take the top of the pump off?
Postby DTanklage » Sun Sep 30, 2007 7:47 pm
mine was like that at first
with the fuel cone removed if you spray a little LPS down there and wack the throttle a few times it might free up and pop out
otherwise yea, you will have to take it apart...
don
DTanklage
Postby swank » Mon Oct 01, 2007 3:32 pm
just in case you were wondering, the best way is to remove the plug on the front of the AFC stack (after removing the throttle linkage). no pump top removal.
truck
swank
Postby DTanklage » Mon Oct 01, 2007 5:02 pm
i thought of that but thought the lever would be in the way?
no?
you ever check your emails?
sent you one about a intake tube...
don (MaxxWedge)
DTanklage
