best turbo upgrade
best turbo upgrade
Postby 6 in a row » Sun Jun 10, 2012 2:01 pm
i have a 90 cummins 5 speed w250 the mods i have done are 5x14 sdx 366 spring fuel pin ground pump bumped 1/8 i have a intercooler out of a 6.0 powerstroke with the plastic tanks might not work idk it was $50 with the pipes and boots no leaks. im looking for a turbo thats good for my setup so far i plan to pull a little with it here and there around 20k and play a little i can buy a hx35 for $75 but ive read that might not be the best im not looking for a turbo thatll break the bank thanks
6 in a row
Re: best turbo upgrade
Postby cmann250 » Sun Jun 10, 2012 2:52 pm
1. Welcome :D
2. Turbo and cheap cannot go in the same sentence. I think that an HE351CW would be the best compromise. I'm sure you have the fuel to spool a 62/65/14 S300, but those are over $1000. I think an HE351 is 60/60/9. A Super40 is under a grand and it's a good upgrade too. By pulling to you mean sled or trailer? That could make a difference
Postby ellis93 » Sun Jun 10, 2012 5:22 pm
You can buy reman HX40's dirt cheap off of Ebay and Amazon,some even have a T3 flang on them. I've seen them for less than 500$
Postby 6 in a row » Sun Jun 10, 2012 6:18 pm
lol i know turbos aint cheap but what did the 351cw come off of or what year cus i can only find a 351ve and pulling its usally a goose neck id like to try it hooked to a sled but didnt know how hot itd get and i plan on buying another fuel pump like an electric one. ive thought about the hx40 also. at 70mph i run around 850 but would a different turbo help with that? do you guys think that intercooler will work? thanks cmann and ellis
6 in a row
Postby oldestof11 » Sun Jun 10, 2012 6:44 pm
HE351CW came off of the 04.5-07 5.9L Dodge Cummins trucks.
Postby Hansen01 » Sun Jun 10, 2012 7:18 pm
I uprgraded from a 35 to an he351 and it made a world of difference still gets hot on the top end but much better than the hx35
Under construction...
Hansen01
Postby 6 in a row » Tue Jun 12, 2012 4:55 pm
ok ill watch for a 351 thanks guys
6 in a row
Postby remi » Wed Jun 13, 2012 8:21 pm
how would an hx40 do in the truck in my sig
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Postby ellis93 » Thu Jun 14, 2012 8:57 am
Depends on the exhaust housing,from what I read,if its a 16 then it'll do well.
Postby cmann250 » Thu Jun 14, 2012 11:36 am
There's tons of variations of HX40 and the Super 40 is the best. It is 60/65?/16. The exhaust housing is gated and the compressor wheel has 7 blades, that's how you'll identify it. The P/N is floating around here somewhere. You'll hear that HX40s are weak and like to break shafts, but for the price and the amount of air they move, they're pretty nice
Postby ellis93 » Thu Jun 14, 2012 3:45 pm
cmann250 wrote: You'll hear that HX40s are weak and like to break shafts, but for the price and the amount of air they move, they're pretty nice
That is only on p-pump trucks or heavilied over fueled trucks.
Postby bmoeller » Thu Jun 14, 2012 3:58 pm
The HX40 is a decent turbo, but found it lacking.
Been too long, but if you can get at the wastegate and drill the divider out so it can 'gate all 6, that will help a lot. They are very laggy, even on an auto.
A 351CW with an external wastegate would be a nice setup. The 9 housing will choke the motor too easy. Drilling the wastegate hole out bigger will help. Just not sure how well it will flow, vs an external gate.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby GoldenRule » Sat Sep 15, 2012 8:13 pm
I'm rebuilding an H1-C w/ wastegated 12cm exhaust housing and upgrading to a 60mm compressor wheel and housing kit (Gillett Diesel). Will have about $400 into it, should be a good value option. Has anyone used a 351 with a controller on a 1st gen? Does the exhaust brake feature work with a Fleece controller on our trucks?
GoldenRule
Postby oldestof11 » Sun Sep 16, 2012 2:57 am
The controller needs input from sensors we don't have so no.
Postby Tacoclaw » Sun Sep 16, 2012 10:00 am
I'm sure you could make the '40 work on most any truck, but they don't like to be barked. Since your truck is a stick, it getting barked between every gear during a hard run might be rough on it. Just some common sense in how you treat it would probably keep it alive regardless.
I'd still +1 the 351 though. Hog the 'gate out and get it venting all 6 and I bet it's just about a perfect turbo for our trucks. Plus they seem to be pretty good in twin sets if you ever decide to take that step.
