Overspeed damage?
Overspeed damage?
Postby Begle1 » Thu Oct 04, 2007 6:13 pm
What sorts of damage could one expect from, ohh, let's say 5-8 seconds of valve tappin' due to over-generous use of ether?
Postby KTA » Thu Oct 04, 2007 6:23 pm
Broken rings and pistons.
Postby Begle1 » Thu Oct 04, 2007 6:28 pm
What about on the valvetrain?
Postby KTA » Thu Oct 04, 2007 6:29 pm
Most likely none, perhaps a bent pushrod or two.
Postby dpuckett » Thu Oct 04, 2007 6:37 pm
Someone has to ask; may as well be me. WHY are you using ether in Arizona? Or did you take a trip to the mountains? We're still seeing mid to upper 80s for highs.
DP
Postby Begle1 » Thu Oct 04, 2007 7:40 pm
Truck wouldn't start. Starved for fuel.
I guess the filter got clogged, compacted itself and sucked air.
After taking it up to 5000 RPM it cleared itself out and worked fine enough to limp the 2 miles back home.
Postby Begle1 » Sat Oct 06, 2007 7:10 pm
KTA wrote:Most likely none, perhaps a bent pushrod or two.
Are there better-than-stock pushrods available that are worth it?
I'm changing out valve springs soon; pushrods are real easy to do at the same time, right?
Postby mhuppertz » Mon Nov 12, 2007 8:01 pm
If you didn't hear a BOOOM RATTLE RATTLE RATTLE the short block is most likely OK.
mhuppertz
Postby ford69557ci » Tue Nov 13, 2007 6:00 pm
i get these worthles frieghtliner buses that wont start all of the time and they have a 5.9 24v. I ether the :grrr: out of those engines and have never had a problem. They do sound kinda rough till they start runnin on thier own and clear out the ether but afterwards they keep runnin fine
ford69557ci
