Afc is leaking
Afc is leaking
Postby cummins32 » Fri Aug 31, 2012 1:55 pm
Well, my afc is leaking, I've torn the pump top off before and put a 3200 rpm spring so I know how to get that far but how do you get the pin out to put a new o ring on, and I have a denny t stage 2 is that part of the problem ?
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Afc is leaking
Postby hydroshok » Mon Sep 17, 2012 9:57 am
There is a thread floating around with a part number to a longer pin so it doesn't mess with the 0-ring and some youtube vids on replacing everything.
hydroshok
