by eyoung429 » Tue Oct 23, 2007 5:42 am
Well, considering I have a degree in mech. engineering and have built every engine I have ever run, I have enough faith and tooling that I can pretty much do whatever I need to do to my own stuff. I still have all of my fingers, excellent hearing and dang good eyesight so I must be doing something right.
It doesn't take rocket science to do your own work, just precision and seeing how anyone who has ever done any mods to an engine had to "do it the first time to see what it does" applies here as well.
I have already been in touch with several manufacturer's and ordered different sets of rings and gaskets, just waiting for them to come in and do a lot of measureing and a little bit 'o cuttin.
Just calm down Roxxx, I promise that I won't tear into your rig to test. I have a little stash of blocks that have already been windowed or had the KDP trash them, this and a few heads that are either cracked or had severe damage (aka...valve drop, excessive heat, turbo schrapnel) for my test subjects.
I also have 2 mills that I am building, one will be a mild motor w/only 40 psi boost and the other that will be above 50psi when done.
You think that discovering how much you can mod the VE came up overnight and by accident?? Nope, this was done intentionally and by LEARNING what can and can't be done. I have found out the very same way by practice over 20yrs on gassers, NA, blown, and Nitrous.
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
