Crankshaft question?
Postby Doge Ram 350 » Wed Oct 17, 2012 10:01 am
I want to swap from Automatic to 5 Speed. Have a complete 5 Speed Truck to Part out.
Can I mount the Transmission without Problems on my Cummins Engine that was Stock an Atomatic?
I´m not sure but is the hole deep enough in the Crankshaft for Transmission Input Shaft? Or are all Crankshafts the same?
Let me know
Here is a Pic from my Automatic Engine
Doge Ram 350
Re: Crankshaft question?
Postby 4thesporty » Wed Oct 17, 2012 11:59 am
All crankshafts are the same...no problem putting the 5 speed on it.
1994 Chevy K3500 12V/NV4500
Full rebuild with mahle non I/C pistons, 370s (set @ 250 bar), HX35/HT3B, custom cam, studs and orings. Yep, it's a VE :)
Still in progress
4thesporty
Postby Doge Ram 350 » Wed Oct 17, 2012 12:05 pm
Sounds great. Thanks ;)
Doge Ram 350
Postby ahale2772 » Thu Oct 18, 2012 4:12 am
make sure you use the correct flywheel specific bolts.... it could get messy if you try and use the flexplate bolts on the flywheel
Postby Doge Ram 350 » Thu Oct 18, 2012 7:37 am
Yes I will use all Parts and Bolts from the Engine with the manual Transmission.
Doge Ram 350
