Guys,
         I went to install my DB fuel pin and found out the slide pin in the AFC will not push out.  I have no idea how long it has been like this. What do I need to do to fix this?
Thanks
dodgeman1990.5 wrote:you will also have to pull the throttle lever off to get to the plug. the shaft that comes out of the pump is splined and can go into the throttle leaver a dosen diffrent ways so make sure to mark it or you will have to take it appart a dozzen times to get it in the right spot. also it is spring loaded so make use you pay attn. to how everthing hooks up.
 Been there, done that
