Removal of pieces of FSS rubber.....
Postby DodgeFreak » Tue Oct 23, 2012 5:17 am
Pretty sure the rubber pieces from the two FSS Tips finally found there way to the dv's. Should I remove all the dv's at the same time and then crank it over to push fuel out and flush it out if I don't find anything??? do I need to replace the copper washers???
Re: Removal of pieces of FSS rubber.....
Postby cummins32 » Tue Oct 23, 2012 8:54 am
I had the same problem, but I took the pump top off cleaned out the rubber that I could find and started it back up and it's fine, I may have gotten lucky though, because part of the rubber got stuck on top of the injector.
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Postby turboram » Thu Nov 01, 2012 7:09 pm
I just pulled the dv on the cylinder that was missing and put 10,000mi on it since
turboram
