P pump block
P pump block
Postby Ram360man » Wed Oct 24, 2012 10:33 pm
P pump engines have the same block as a ve correct? Found a short block for 400 out of a 95. Only need the block. Otherwise I have a bluebird with a ve I can pull the engine from.
1989 W250. Maxed fuel pump. 5x14. 63/68/14. PS Intercooler. 4200 gov spring. 188/220 cam. Built 727
1989 W250 60mm gds. 2.5 inch crossover. turned up pump. Stock 727.
Ram360man
Re: P pump block
Postby Philip » Thu Oct 25, 2012 5:49 am
Blocks are the same.
The heads are the same other than a p-pump head does not have the holes drilled or taped for 1st gen throttle linkage mounting. The IC heads I mean. The nonIC heads are different.
