Hello, i am Buying a 1989 cummins with a 1992 5.9 intercooled cummins. The owner said that he drove it from work and started next morning and there is a knock. He said it is the Thrust bearing and it would take a couple hours to Replace them. i am new to owning a cummins and have wanted one and want to know if 3500 Dollers is a good Deal? the motor has 133k miles and is all stock. also are the thrust bearings easy to Replace?
Also what does the knock sound like for thrust bearing? Give your best explanation. Thanks
