OK,
On worn VE's.
I have heard of spraying cold water on the distributor head while running is a diagnosis for a worn cam plate and I found an easier way tonight.
I replaced the injectors to improve the smoothness and power of the engine. Injectors were good, pulled old ones which only had like 5 ft lbs on the retaining nuts. New injectors went in with a little bit thinner sealing washers, buttoned it up and started it. Would only run on 2 or 3 cylinders! No power at all! TONS OF WHITE SMOKE and POPPING! Timing wasn't moved today. Timing was 1/8" bumped 2 months ago and pin was ground and afc tweaked. The engine was constantly pushing air bubbles in 3 lines which were cracked while running and did not affect the engine running. Closed them up and proceeded. Tore pump side apart, checked FSS (was good) checked KSB (was good), changed over flow valve (no difference), backed timing to stock (no difference). I then remembered that the KSB increases case pressure slightly when engaged. The intercooled trucks KSB activates and with power is like an FSS. With 12v, the intercooled KSB extends out and blocks the flow of fuel to the return line thus raising case pressure. Doing this with a jumper wire, the engine within 2 seconds went from running on 3 cylinders to running on 6 with no air bubbles and a much higher idle (than it was). KSB activated idle was about where a stick shift truck with factory settings idles in neutral.
Conclusion,
The new injectors had close pop pressures and weren't beat up like old ones, the bubbly fuel supply couldn't build enough to pop them except once every few seconds. This led me to believe I have a head and rotor issue. The truck had the same symptoms as mentioned above such as, when in reverse and then hitting the breaks, the lurch would stall the engine, when hot, the engine missed badly and ran rough at idle, the full throttle RPMs would pop and blow white smoke, very low power, horrible fuel mileage (13-16 mpg).
I band-aided my pump for the next week hoping it won't crap on me. I'm buying a core pump, rebuilding it and if the core needs parts, I will ask my buddy who has half a dozen parts pumps. IF I FIND BROKEN SPRINGS in the delivery valves and cam plate area, I will buy all new springs for the 6 delivery valves as there are plenty of cases of broken DV and Camplate springs. With that, expect to see my homebrew VE rebuild......
Final conclusion
Is it just me or are there a lot more intercooled trucks with pump issues than non IC? I wonder if bosch changed the metallurgy of the rotating pumps to something more inferior or the changing of delivery valves and a different KSB put harder loads and wear on rotating parts. As for now, the '93 has a pile of puking metal spinning around that somehow keeps it going to and from school, shop and work.....knock on wood.
Peace out
Charlie
