Pump Raining Fuel
Pump Raining Fuel
Postby whereswaldo250 » Wed Oct 24, 2007 7:30 pm
Well, I went to start my truck yesterday and I left it idle to warm up like any diesel person would and I come back to leave and there is something dripping from underneath the truck. It turns out it was fuel and I popped the hood and the IP was leaking from the back side (side closest to block). I am on my knees because it just happened out of know where. Do you think some seals went bad from the ULSD? I am stuck and I do not know what to do :cry:
Thanks
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby Begle1 » Wed Oct 24, 2007 7:42 pm
It's probably just a seal; most people nowadays blame seals on ULSD.
How hard it is to change the seal depends on where exactly it's leaking out of the pump.
A seal kit for the VE pump is Bosch part number DGK-121 and costs $20.
Postby PToombs » Thu Oct 25, 2007 3:38 pm
Try to look at the back. There is a cover there on the opposite side from the KSB. If thats leaking, you have to pull the pump. (what i've heard)
Postby whereswaldo250 » Sun Oct 28, 2007 4:37 pm
Begle1 wrote:It's probably just a seal; most people nowadays blame seals on ULSD.
Thanks Begle for the part number but I think that I will have to take it in to be done :cry: I need my truck for school and work. At least I will get the 3200 gov spring
whereswaldo250
