Cheap fan bearing alert !!!
Postby D-dog357 » Mon Jan 14, 2013 11:37 am
OK folks here's a Kmart blue light special for you -
I was on flee-bay this morning and a new listing for our fan support bearings has them for only $30 plus shipping. Mine came to $44. :shock:
They are listed as loose and new with minor scratches and dings. Only list 10 available.
Hope this helps others in need.
D-dog357
Re: Cheap fan bearing alert !!!
Postby RumbleFish » Mon Jan 14, 2013 1:08 pm
Got a link??
Postby dunes450r » Mon Jan 14, 2013 1:36 pm
how often do fan bearings go out? i've never heard of them going out, but apparently they are expensive when they do?
dunes450r
Postby ellis93 » Mon Jan 14, 2013 3:25 pm
I have replaced three,including my own. In maybe 4 or 5 years
Postby Mark Nixon » Mon Jan 14, 2013 5:05 pm
RumbleFish wrote:Got a link??
Here ya' go, buddy:
http://www.ebay.com/itm/CUMMINS-FAN-SUP ... 5e&vxp=mtr
Postby Black93 » Tue Jan 15, 2013 8:56 am
I just bought one. They'll take $25 if you make an offer. They have 6 left.
Black93
Postby Mark Nixon » Tue Jan 15, 2013 9:28 am
Black93 wrote:I just bought one. They'll take $25 if you make an offer. They have 6 left.
LOL, I JUST did the same thing and got 3.
Interesting, once you make an offer for a certain quantity and the offer is accepted, they must reserve them, because I got an acceptance e-mail at 7AM, my time, and it showed 6 available then.
Postby bmoeller » Sat Jan 19, 2013 2:32 am
Before you install the new bearing, pop the dirt shield off of one side, and add more grease. The factory puts very little in there! I picked up some synthetic grease, and managed to get 5 more shots of grease in mine (bough it through the KW dealer for 1/2 what Dodge wanted for it).
Need to replace that bearing on my 93 and donor engine.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby PToombs » Sat Jan 19, 2013 4:48 pm
2 left now!
Postby RumbleFish » Sat Jan 19, 2013 5:30 pm
Mine should be here any day!
Postby ellis93 » Sat Jan 19, 2013 6:15 pm
FYI,if you press the bearing in the housing yourself make double damn sure that you have it straight in the hole. I busted my housing cause I wasn't paying attention and let it cock in the hole,next thing I heard was "tink" and Walla,instant I'm screwed served hot and fresh. I had to contact our local parts supplier Mark Nixon for another,which still is sitting in the tool box of my truck cause I welded the other up :mrgreen:
Postby bmoeller » Sun Jan 20, 2013 7:13 pm
I got the last 2. :) Sure beats $150 for one! :D Exact same bearing too!
bmoeller
Postby D-dog357 » Mon Jan 21, 2013 7:06 pm
You guys are a tough crowd !
Here I save your sorry butts some serious cash and not even one thanks for the heads up.
BTW, mine finally arrived :D
'92 ex-cab, A/T, 3.56, timing bumped 1/4" , 366 w/ fuel 1/2 turn past collar, smoke all the way out and a ported HX hot side. Airbox and core support drilled for more cold air.
A no budget work truck.
D-dog357
Postby Greenleaf » Tue Feb 05, 2013 10:35 am
Let me know how that 25-30 dollar bearing holds up.
Same part, huh? :shock:
Greenleaf
tech specialist/mod
Postby bmoeller » Wed Feb 06, 2013 4:36 pm
Greenleaf wrote:Let me know how that 25-30 dollar bearing holds up.
Same MFG and P/N as stock.
bmoeller
