rolled truck
rolled truck
Postby (92)cummins » Tue Jan 15, 2013 8:31 pm
i rolled my truck november when it was real icy, it was upside down for only about 20 min and as soon as it rolled i shut it off is there anything i shuld check before i try starting it again?
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: rolled truck
Postby bubba » Tue Jan 15, 2013 9:29 pm
I'd make sure it was full of oil ;)
1992 Dodge W350 CTD A518 DRW Flatbed
bubba
Re: rolled truck
Postby (92)cummins » Tue Jan 15, 2013 9:38 pm
haha i suppose oil is kinda a given and the tranny fluid didn't feel like defying gravity and leaked through the vent on top
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: rolled truck
Postby bubba » Tue Jan 15, 2013 11:04 pm
The only thing I can think of would be to pull the injectors and spin it a few times to make sure no oil is in the cylinders. I'm not sure if its required or recommended for a rollover but seems to me thats the biggest thing. I once rolled a bronco II over and waited for my dad to get there with his truck, got it right side up and hit the key. It smoked and rattled for a few but then it was ok. But that V6 ford had a lot less compression and would have been a lot cheaper to replace than a cummins :lol: I've seen guys crank down on the exhaust valve adjustment to keep the valve open for pressure to escape if you didn't want to pull the injectors. Lastly I'd check the air filter. If its saturated with oil it'd cause trouble.
bubba
Re: rolled truck
Postby (92)cummins » Wed Jan 16, 2013 7:21 am
alright ill see wats in the injectors last thing i would want to do is fix the body amd then wreck the motor
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: rolled truck
Postby PToombs » Wed Jan 16, 2013 6:07 pm
If you rolled it back in november and then flipped it over in 20 minutes, (while it was still warm) I would go ahead and start it. Since it was still warm and it has been sitting since then, most of the oil has drained back thru the rings, except for some residue. It will smoke like a pig and run rough until it gets warm and cleaned out, but it should be ok. If you are nervous, try turning it over by hand before you start it.
Re: rolled truck
Postby (92)cummins » Wed Jan 16, 2013 9:36 pm
alright, 18 yr old can never b to careful obviously since i rolled
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: rolled truck
Postby BobS » Thu Jan 17, 2013 6:06 am
Disconnect the solenoid wire and crank it for 15 seconds. If it spins normally then hook up the solenoid and light her off.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
