Changing the serpentine belt -an easy cheap tool
Postby monoblock » Sun Jan 20, 2013 9:57 pm
The challenge in fitting a new serpentine belt(Gates FleetRunner K080830HD with a/c+intercooler) is that you need 3 hands. One hand is required to operate a 3/8" drive, 17" breaker bar($8 from Harbor Freight). The other two hands are required to slip the belt over the top of the alternator pulley. If the belt seems too short, check that it is not caught up on a protruding bolt head way down next to the crankshaft pulley.The offending bolt head is on the driver's side and you'll never see it from below or above -just fiddle and grope until the belt lies tight to the curve of the c/s pulley. If the belt seems too long, you forgot to make a routing diagram before you removed the old one ? The sticker on the lip of the hood showing the belt routing is a bit vague and faded ? Geno's has a good diagram if you did forget.
Before you fit the belt it is a good idea to spin the idler pulley to feel for roughness in the bearing. At 48,000 miles & the original belt my bearing has just a slight roughness so I'll fit a new pulley soon (when I replace the fan+fan clutch with an electric fan) Dayco 89005. It is worth checking the water pump pulley also.
To hold the end of the breaker bar so that the tensioner pulley is correctly positioned, I used a cheap ratchet strap . Make a few turns round the end of the breaker bar so the strap doesn't slide off. Wrap the other end around the convenient bracket on the passenger side fender wall -see photo-(if I can figure how to upload without an image host like Photobucket). The bracket has a sturdy bolt,wing nut and bracket on it -very convenient to loop the strap around. You can use the ratchet to get full movement of the tensioner Then you can use two hands to slip the new belt on the alternator pulley . It is then easy to check that all the grooves of the belt are correctly engaged in all the pulleys that have grooves. Don't forget to remove the ratchet strap and breaker bar before you start the engine!
monoblock
Re: Changing the serpentine belt -an easy cheap tool
Postby dazedandconfused » Mon Jan 21, 2013 6:44 am
I've never had issues getting the belt on with one hand but I've heard others complain they couldn't get it. As for the pictures you have to use a photo sharing site like photobucket
Postby bmoeller » Mon Jan 21, 2013 6:48 am
Putting a belt on my 92 was a SOB. Went easy on the 93. It's weird. Just enough of a variance, i guess.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby dunes450r » Mon Jan 21, 2013 12:39 pm
i changed mine in about 5 minutes by myself with just a standard 3/8 ratchet. just be careful not to bend too many fins on your radiator depending on the clearance you have between the fan and radiator
replacing the idler pulley helped my shutoff belt squawk a bunch, and got rid of a small squeak at idle that had started developing
dunes450r
Postby RCCUMMINS89 » Mon Jan 21, 2013 12:52 pm
Idler pulley is somewhere on my list... my truck has a cricket upon start up that lasts for about a half an hour.
Postby PToombs » Mon Jan 21, 2013 6:51 pm
I slide mine over the waterpump last. It's easier because it's a smooth pulley, no rib on the edge to fight with. Plus I get lots more practice than most of you guys. ;) If you wanna have fun, try doing it on a Case backhoe when the hydraulic pump is stuck on the splines and won't slide back. :evil: (the pump runs off the front of the crankshaft)
Postby monoblock » Sun Jan 27, 2013 11:44 am
Harbor Freight have a tool kit for this that is on sale now for $9!
Item #66344
http://www.harborfreight.com/catalogsea ... ntine+belt
monoblock
Postby bmoeller » Sun Jan 27, 2013 12:02 pm
PToombs wrote: If you wanna have fun, try doing it on a Case backhoe when the hydraulic pump is stuck on the splines and won't slide back. :evil: (the pump runs off the front of the crankshaft)
Same goes for their skidloaders...................
bmoeller
