Hi, need help
Hi, need help
Postby krewlkid » Sun Jan 20, 2013 11:35 pm
ive been lurking here for a while, been on CF for a while, been have some problems maybe you guys can help..
both are videos, please click
at rest
driving
WOT cuts out, truck drive and runs fine if i dont go to high in boost
mods are
1992 w250 LE auto BHAF, M3, fuel turn up a little, DE 4", Skyjacker 2.5", 3rd gen wheels
krewlkid
Re: Hi, need help
Postby Horus » Mon Jan 21, 2013 3:41 am
I can't get the videos to play. Can you give us any more info?
Go make sure the wire connectors are solid to the fuel shutoff valve. Mine came loose and the solenoid would intermittently cut out at weird but specific times.
91.5 W250 Dodge 4X4 CTD. Getrag. DD Power pin removed, stock fuel cone back in. 366 spring. Power screw at stock depth. Stock turbo. Stock lift pump. Straight piped and Intercooled.
93 D250 Dodge club cab 2wd. All stock for now. Automatic.
Hard KOR Wheeler.
PNWJeep club member.
Horus
Re: Hi, need help
Postby cmann250 » Mon Jan 21, 2013 5:58 am
Sweet! EFIlive has finally reached the 12v crowd. We have a lope tune!
I doubt it's boost related because you're not making much boost just reving it. I'd second the FSS connections
Re: Hi, need help
Postby bmoeller » Mon Jan 21, 2013 6:44 am
I'd pull the FSS out, and see if the rubber tip has broken off, blocking the hole a bit. Sounds like a fuel supply issue.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Hi, need help
Postby dunes450r » Mon Jan 21, 2013 12:35 pm
hmmm, thats very odd. i don't think it much of a fuel supply issue because it has enough fuel to spool the turbo pretty hard (by the sound) before it lets off, but when it lets off it sounds like just goes to an idle which to me sound different than when the FSS is intermittent (i had FSS issues that on hard acceleration the wire would pull off the FSS, then the jolt of pickup losing fuel would be enough to make the connection again)
wish i could be more help
dunes450r
