14mm pump
14mm pump
Postby cummins king » Sun Oct 28, 2007 12:23 pm
okay heres a dum question that i dont know the answer to, why cant you make 14mm pump and make it bigger to a 16mm, you would need a big turbo, realy big injectors, what you think
93 4X4 auto
cummins king
Postby ford69557ci » Sun Oct 28, 2007 3:28 pm
i think it has somethin to do with the 16mm plunger assyembly being to heavy and not being ablbe to run higher rpms but i could be wrong.
ford69557ci
Postby Begle1 » Sun Oct 28, 2007 5:12 pm
I believe that anything after 14 mm required a total redesign of the cylinder; the 14 is a bored out 12, but there isn't enough material to bore it out to 16.
And there isn't enough of a market or advantage in going to that kind of expense.
It'd be more inertia to overcome at high RPM, but I think the extra fuel that it would flow would be more than enough to make up for that.
That's my take on the situation, anyways.
Postby ford69557ci » Sun Oct 28, 2007 6:05 pm
i was lookin at my 14mm head and plunger and it looks like there would be enough room for maybe 15mm but not 16 i just wonder how much more flow could be had cuz i can probably get one made for under 500 bucks
ford69557ci
Postby KTA » Sun Oct 28, 2007 8:02 pm
Going to be tough when the ball for your control collar is digging into your plunger.
Postby ford69557ci » Sun Oct 28, 2007 8:21 pm
thats could probably be a bad thing lol. couldnt some of the ball be macined off?
ford69557ci
Postby cummins king » Wed Nov 14, 2007 4:00 pm
KTA, how hard is it to install the 14mm pump
93 4X4 auto
cummins king
