5.9 engine ID or serial #?
Postby jdaivs1 » Mon Jan 28, 2013 6:43 pm
Can someone tell me where I can look up a ID or serial number to verify which 5.9 This is? Example did it come with a ve pump or a what ever pump and injectors. My friend is look to buy a motor from a guy. But the guy does not seem to know much outside of it came out of a 2 1/2 ton truck. Here is the Id and serial # if that will help ID# 56501159 or Serial# WCEXH0359BAE or if you can tell me where to look up this information that would be great!
93 w250 auto, fuel screw turned in
jdaivs1
Re: 5.9 engine ID or serial #?
Postby comotionman » Mon Jan 28, 2013 10:09 pm
call your local cummins franchise
coupla trucks non & ic, 2nd gens, various other
comotionman
Postby jdaivs1 » Thu Jan 31, 2013 8:45 am
comotionman wrote:call your local cummins franchise
Thanks, they had the answer.
jdaivs1
Postby skilletky » Thu Jan 31, 2013 10:22 am
vin number-49H67FAC6XHA85103
build date-11 Sep 1998
CPL2447
ISB-195 ENCORE
ISB CM550
here is some more info for that serial #.
skilletky
Postby skilletky » Thu Jan 31, 2013 12:27 pm
was board and looked the vin up, its from a 1999 sterling SC7000
skilletky
