skilletky wrote:ive run the felpro and cummins. both the same if you ask me. ive blew both of them with in a month. the third one i ran was a felpro. lasted a year at 45 psi and stock head bolts. i got a .020 over victor reinz now. with studs and an o ringed head, its held up to 70 psi of boost several times and sees 45 to 50 psi + W/M about every day. dont reuse your old stock head bolts. get new ones, clean the head bolt threads up in the block, and use a good lube on the threads and bottom of the head bolt head.
odee wrote:guys got my head back from the machinist, took 5 thousands off the deck surface. The machinist said that I would need a thicker gasket because of the cut. The fel pro that I bought prior to the work is thinner than the one that came off. He said the valves may hit, his shop sales the victor reinz gaskets any good? I'm having second thoughts of this on using the felpro vs the cummins part or victor. Any more input on this?
