how to tell if I have a knock
Postby Dodgecrawler2011 » Sat Mar 02, 2013 6:11 pm
Kinda new to this cummins stuff but. When the truck Is at idle it all sounds normal. But when u rev it a bit it kinda has a knock sound comeing from the back of the engine. Its only when u touch the throttle and goes away Instatilly. Also I pulled the timing cover off to checl the kdp and its gone. Theres signs that it fell out and made some scrathces on the cover. Should I drop the pan I get it out.
Dodgecrawler2011
Re: how to tell if I have a knock
Postby directinjktn1stgen » Mon Apr 01, 2013 4:08 pm
its to heavy to get picked up in the oil strainer and far to big to fit through it i wouldnt worry with it may fall out upon your next oil change if hasnt already
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Postby apexfd » Sat Jun 01, 2013 9:12 pm
I was glad to find my KDP had not budged.. Although my truck has a bit of a knock, I think its worn injectors.
apexfd
