How similar is this Bosch pump procedure to our pumps?
Postby BobS » Wed Jan 10, 2007 2:48 pm
This is a thread on assembling a 4 cylinder Bosch pump on a Pugeot. Very good pictures. I know the head and related parts are different. My question pertains to the procedure in putting it back together. Here is the link:
http://www.vwdieselparts.com/forum/viewtopic.php?t=5392
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby sdstriper » Wed Jan 10, 2007 3:28 pm
I have seen that one before without the translation. I think your good to go with that photo guide. Need the schematic?
sdstriper
Postby gman07 » Wed Jan 10, 2007 3:36 pm
I've taken apart a VE (never put one back together though), and it was very similar to that guide. The governor is slightly different on ours, but it's easily understood once you see it.
gman07
Postby rlyons » Wed Jan 10, 2007 4:50 pm
The spring that is shown between the drive and the wobble plate does not exist on the Dodge version but the rest is the same.
92 D250 Club Cab 4X2, 5 speed, ASA Modifieds Intake, Jannetty Racing Team Exaust System, Tweaked Pump, 3200 RPM Governor Spring, HTT Stage III Turbo w/16cm2 , Pyro/Boost/Tach Guages, Power Wagon Injectors, KDP Tabbed, Borgeson Steering Shaft.
rlyons
Postby BobS » Wed Jan 10, 2007 6:37 pm
sdstriper wrote: Need the schematic?
If you mean the exploded view I think I have that somewhere as a jpg file. That same website HAD a link to a VE manual in pdf format but the link no longer functions. It would be nice to have the clearances for reference.
I am gathering information to teach myself how to put a VE together when the need arises. :wink:
BobS
89 D350 Stock
BobS
Postby gman07 » Wed Jan 10, 2007 7:21 pm
The governor spring is slightly different on ours. Here's a picture of theirs:
http://bricofoy.free.fr/voiture/pompe/dsc05404.jpg
vs. ours:
http://bb.1asphost.com/gman07/cap.jpg
gman07
Postby Greenleaf » Thu Jan 11, 2007 7:18 am
I see somebody was busy inside that pump top :lol:
Greenleaf
tech specialist/mod
