IRoss wrote:The other day while doing an oil change I gave my fuel screw another half turn, which effectively bottomed it out, from the feel of it....along with this power came an extra 3-4 minutes of cooldown time to reach 300...its running noticably hotter in the lower (1800)rpm range than the upper(2400) rpm's. Now will un-adjusting the smoke screw (fuel under low boost, right?) help ireduce egt's while just cruising around at low rpm, allowing the it to cool down a little faster,? Could it have anything to do with the oil? (shell 15w40 Rimula, just switched fr/rotella)
thanx, ian
PToombs wrote:Flash I think you got it backwards a little. If the smoke screw is turned in, the starwheel won't affect it any. The screw will lower fuel on the bottom if you back it out. It overrides the spring at idle, pushes the cone down.
If you turn the starwheel down, it will fuel faster when boost comes on, up, slower.
PToombs wrote:Yup, you got it. Spring pushes up, boost down. Screw pushes down. Down is more fuel, fast down, faster fuel!
PToombs wrote:What, this?
