cam plate
cam plate
Postby turboram » Sun May 19, 2013 6:20 pm
Has anyone tried the 4mm lift cam plate with any luck? I dont want to order one if they are a complete POS. thanks guys
turboram
Re: cam plate
Postby dazedandconfused » Sun May 19, 2013 6:36 pm
From what I've read they drained the pump to fast causing them to sieze. You may be able to keep it alive with the dual feed. I've also seen a 3.2 advertised.
Re: cam plate
Postby RCCUMMINS89 » Sun May 19, 2013 7:03 pm
I think the longest one has ever lasted was about 10 minutes on the test bench.
I look at it as a challenge for you.
Now Rockentech's stuff is pretty much garbage though. IMO which makes it hard to get anything worth while
Re: cam plate
Postby turboram » Sun May 19, 2013 7:33 pm
where did you see a 3.2 plate
turboram
